641 - 660 of 1,621 Posts
what u need belly skids and what not for they wil have come out with soft rock by the time this is done:poke:
Discussion starter · #643 ·
well got some time for tinkering today, so pulled my t-case, be dropping that off to have it put together for the doubler/sye, then installed the spicer joints in the D44 shafts, installed the spindle bolts and messed with the hy-steer studs, not installing those until get the drag link hole drilled where ever it needs to be. Picked up Spicer ball joints as well, why not right? Gears are installed on the 44 as well so bout time to start adding the brackets to it. :woot:
Discussion starter · #645 ·
thought u were putting in cheapy ball joints? any news on the 8.8 gears?
had to wait to get elcheapo joints and well i thought it be better to just be done with it and go with the spicers.
8.8 gears been here. :thumb:
ic what ever i guess makes things easy any idea when you'r putting the brackets on and what not?
Discussion starter · #655 ·
all he did was jack it up and put different tires under it :sonicjay:
and pulled the drivtrain, got the gas tank setup together, BW pulled last night as well, cutting the rear up tonight. Also finished up the new floors as well.
