242K views 1.6K replies 139 participants last post by  MiNiBeast
#1 · (Edited)
ME:
Maybe afterwards...
Recognize me yet...
member?
http://cgi.ebay.com/ebaymotors/84-9...QitemZ150214478003QQihZ005QQcategoryZ33708QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Well got my RK 3 link LA kit.
http://rustysoffroad.com/mm5/mercha...chant.mvc?Screen=PROD&Store_Code=rustys&Product_Code=RB-SBL10-UV&Category_Code=
:rock on:
#3 ·
Hoping to get it done by the 19th then whenever from there. Won't have the gears in the front by than, the 19th, but hopefully before july. Going up to Silver for the 4th, then going down to the Badlands on July 18th to 20th so need to have 4x4 done by then.
#6 ·
Well with *********'s help, got the ube on tonight.
Got the 8.8 up on jack stands
Me...
Did a little grinding on the UBE to get that snug fit...
A little touch up to better suit *********...
Now some measuring...
Measured off *********'s Jeep
Pinion angle was set at 88*
Cut off axles mounts for emergency brake cable bing they hit the UBE, being the width was center to center spring bolt hole, 43 3/8"
Then spot welded to keep UBE from tweaking...
Now for a full weld...
Then the rest of them...
1 1/2" spring under????
Fuck no!!
Shock mounts pretty much kept in stock position up on axle... lined them up in the middle with the outside edge of UBE..
Done fucker... ********* Customs
Have to give thanks to ********* for he is a busy guy, but he has helped me out when needed. And even more being that the same time last year he helped me put perches on this same 8.8 and put it under my MJ. So Thanks again *********. :beerbang:
#12 ·
Well got the lift in this weekend and it was a fucking pain in the ass. I hate michigan jeeps, so damn rusty.
But done deal now just need to do the typical finesseing to it.
Started putting brakes together and the lines on the axle..
Then started to tear out the rear..
Putting the new one in..
Bud the best tool on any project..
Bolting it down...
Now the front... ditched the crossmember as well
front brackets...
#13 ·
Finishing up on the bracket..
Now the front axle removal...
Working now on removal of lower control arm mounts..
Got to replace the upper mount bushing on axle...
pound it, press it...? I say fucking burn it out!
Install new one..
Now put axle back in with lift springs....
And remember the importance of jackstands and blocking the tires.. these are pics of jeep after the front fell off the jack stands...
Ok so finally got it so I can get the arms on...
lower arms set at 27.75" and upper arm set at 30" as said by RK in install package..
But the pinion pointed a little high and made the springs off center to the bumpstop, so had readjusted the upper to 29.5". Better but still need some adjustments.
UCA at 30"...
Track bar installed but need to re adjust that yet.. and stock steering remains, but for short while. Have drop pitman arm, and new x steering being made up. So install shortly.
Done except for some finessing...
And a side note.. learned the importance of one of these...
Buddy caught the steering shaft on fire, the plastic cover, so before it took out anything else of importance we use the red thing.
He she is on the 33's...
then the before we lifted it...
#20 ·
Installed the extended brake lines today
Yeah well got my lines on today up front anyways. I need a new rear line being that during the swap it got toasted by the welder, so replace someday.
But yeah didn't take long for the install, just cut off the ends and added new ends and flared the lines and installed, like 5min for each line.
My helper...
#26 ·
WP Warrior bumper installed
So I wanted something for now just to hold me over untill I get a new bumper, so a guy had this bumper and was going to scrap it, I told him I'd take it just so I can have something a little stiffer up front then the stock bumper. Never really got a good look at it untill today. And realized it was a WP bumper that goes for $200+, so needless to say I got a great deal and she don't look half bad either. So I put it on tonight....
need to trim some of the fender flares, but had to cut the fenders up anyways so why not now....
