My Yj; 6.0 V8, 700R4, D44, D60, H1's, 37's and OBA - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 10th, 2005, 08:17 PM   #1
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Default My Yj; 6.0 V8, 700R4, D44, D60, H1's, 37's and OBA
Current Picture, Look through thread for buildup:
6.0 updates start here
http://www.greatlakes4x4.com/showthr...?t=665&page=13
Stats and info: (cut and pasted from another site i have the info posted on)
Vehicle year: 1994 (base vehicle),1991,1998,1985, 1984, 1975, 2001 :D
Year purchased: 1999
Engine and engine mods: 2001 Chevy lq4 6.0 77k miles 355 Chevrolet, Mild cam Edelbrock intake and carb, De-emissioned, dual Exaust,
Drivetrain and drivetrain mods: Built 700r4 with manual overrides, Np231C
Axles, gearing, and mods: HP D44 front USA Alloy shafts, Spicer joints Spartan Locker/D60 rear Ford limited Slip, 4.88 gears
Tires & wheels: H1 Double Bead Locks, 37x12.5 Cut BFG Baja (for now), 37x12.5 Goodyear Surplus tires
Lift and other suspension mods: BDS 2" SOA suspension and Shocks, removed Swaybar and Trackbars, modified teraflex traction bar
Exterior mods: Custom Rear bumper built by Nick_sg and I, Front bumper built by me with winch mount and TX2 12,000lb 2 speed winch, Foglamps, rock rails with side step, functional ram air scoops for venting excess heat.
Recovery and safety equipment: Koz Sport Cage, 12,000lb TX2 winch, 8klb Warn rear winch, Hi-lift jack, Strap, Tree saver, and a fire extinguisher, assortment of tools and a rag
Skid plating: Stock Skid's for now
Other mods: YORK OBA, (currently disabled)
Best modification: V8 and the 4 wheel discs and tranny by Killer "b"
Worst modification: Rear Tube bumper, bent too easy, the hitch flexes under load, feels like it would come off-- oh wait it did
Primary trails or events: Mounds, Big Rapids, and Silver lake, have done some Whitehall and would like to hit Grayling and Mio (nothing around my house other then my field), did west branch and St. Helen as well
Club/Organization affiliations: GLFWDA, web-boards and friends
Very near future mods: Tons
and here is my just completed install of the New improved 355. .030 over, mild cam
and yes I know I need to replace my gooseneck gasket... i see it belched anti freeze on the intake it wasnt leaking 3 days ago... but i never changed that seal when the engine was apart as i didnt take off the gooseneck
Old November 10th, 2005, 09:42 PM   #2
Chop
Mischievous Badger
Chop's Avatar
nice jeep good engine under there a little leak never hurt nobody
Old July 20th, 2006, 09:27 AM   #3
jeepfreak81
81 inches of fun
Some Updated pics...
Dirty motor, better wiring
new dash
CNC work on the bumpers
Old September 3rd, 2006, 08:12 PM   #4
jeepfreak81
81 inches of fun
More updated pics....
added a Taurus fan... this required the moving forward of the radiator, and moving the tranny cooler to the front, I used to have a pusher fan...
On High this fan will suck a cat through the radiator... start up draw is in the vicinity of 60 amps (starting right into high speed) though so it required a heavy duty 75 amp relay... I have that protected with a 60 AMP fuse... I am hoping I wont be blowing that, the low speed is auto controlled with a manual override for high speed. I figure I can hold the start up amps down if I only flip on the move from low to high. All lower pics are prior to looming.
on the left is the 3 way in cab switch, on the right is the 75 AMP Bosch relay from a Freightliner
The relays mounted (the relay on the right is a 50 amp temperature controlled relay for low speed)
and while Adam 99grandTJ was wiring it I got busy with a spray can... my jeep wants to be a Renegade II
Just need to add the grates into the Snout holes...
Old September 3rd, 2006, 09:05 PM   #5
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Ghey, anyone can put a 350 in a yj
Old September 3rd, 2006, 09:09 PM   #6
Ebs
What the heck is a 355 Chevy, must be rare :tonka:
Old September 3rd, 2006, 09:13 PM   #7
jeepfreak81
81 inches of fun
It's a 350 bored .030 over :miff:
Adam your just jealous
Old September 3rd, 2006, 09:28 PM   #8
Jeepaholic
Jeepaholic's Avatar
No, I work on that thing more than mine, no thanks
Old September 3rd, 2006, 09:31 PM   #9
jeepfreak81
81 inches of fun
but not because its broke :tonka: we break it upgrading it :tonka:
more pics:
Old October 8th, 2006, 10:18 PM   #10
jeepfreak81
81 inches of fun
more stuff....
Old October 10th, 2006, 10:01 PM   #11
jeepfreak81
81 inches of fun
get it wired, and get the belt and it is useable... though I dont have it plumbed to the front and back yet, just to the top of the tank with a QD
I also need to paint it yet
I should have got the separate oiler/filter ... I need the filter directly after the york to catch the oil before the tank... and The oiler needs to be after the tank.
I need to see if I can separate my set, by the book it looks like I can, I just don't know how I would mount them.
Old October 11th, 2006, 08:28 AM   #12
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Nice YJ!
*2007 Rubicon
*2006 Duramax
Old October 12th, 2006, 10:35 PM   #13
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
My YJ can be going backwards and still out pull yours:tonka:
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Old October 12th, 2006, 10:42 PM   #14
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
I seem to have that same problem. The OBA looks great!!
Old October 14th, 2006, 01:06 PM   #15
jeepfreak81
81 inches of fun
I ran it up to 125PSI working load last night, and ran an impact with NO trouble what-so-ever we re-plumbed some things as I needed to move the location of my oiler in the mix, added a check valve and a second filter. I need to change out some clamps though... the ones I bought at Harbor freight are cheap crap and won't tighten enough I blew 2 lines right off. here is the final deal (minus painting) and I need to run the electrical into the in cab toggle switch yet. I also need to get the intake filter/muffler on -- though it isn't loud at all
also put in my new steering wheel last night... a little ricer like but i REALLY like it...
Old October 14th, 2006, 05:13 PM   #16
jeepfreak81
81 inches of fun
here are some vids... (pressure switch is jumped to the battery, toggle switch isn't hooked up yet) this is very impressive, keeps up with my air chisel AND my Impact, if I turned it off idle I am sure the VERY minimal drop off I see would go away.
Old March 18th, 2007, 02:34 PM   #17
clarkstoncracker
lol
clarkstoncracker's Avatar
Any updates on that OBA system?
Is it still working?
Old March 18th, 2007, 02:42 PM   #18
jeepfreak81
81 inches of fun
It works fine, I have a leak in the hose that leads from the compressor to the tank though, it is a result of using a PVC air hose intended for roofing nailers (the blue hose in the pics)-- I never knew the differences in air hose before, and it could not handle the high temps of the air coming out of this compressor. You cannot use a sub-par line here. Haven't been out on the trail to use it though, but I used it to change a motorhome tire with the impact, and I used the air ratchet to separate a tranny and t-case I gave to Renegade II, worked very well.
Old March 18th, 2007, 05:41 PM   #19
mpsbvp
Hummer recovery team
mpsbvp's Avatar
Send a message via AIM to mpsbvp Send a message via Yahoo to mpsbvp
nice jeep i want it
mpsbvp is offline   Reply With Quote
Old March 19th, 2007, 03:10 PM   #20
Gunsworth
Gunsworth's Avatar
more pics:
Forgot to ask ya at the pig gig, where'd ya get that tire cover? I only ask because I have the same one and never saw anyone else with it . That and my uncle "found" it at work and passed it on to me back in 99'
Page generated in 0.62617 seconds with 84 queries
