781 - 800 of 1,234 Posts
like you have anything to say about the color purple :poke: :sonicjay:
never said it looked bad, just unexpected........................................................................and my old jeep was a funny blue, not purple, the paint code says so
Discussion starter · #785 ·
little spacers to center the rotors to the studs to elimante any play in the rotor at axleshaft mating
Purple and done :teehee:
painting the center section before installing the third leaving the outsides primer till the spring perches, shock mounts, and brake calipers are welded on
Discussion starter · #795 ·
i had to grind the caliper brackets i bought to fit on the axle, the pads and rotors didn't line-up as in didn't sit with full contact surface of the pads against the rotors. all better now, the brackets are welded to the axle.
the grinder kinda got away from me on the first one lol
Discussion starter · #800 ·
I cannot get the D44 gears installed with a good pattern...this thing is kicking my ass. I have gone through all kinds of shims, moving them around, taking the pinion in/out and replacing shims..........I am starting to wonder if the i do not have a housing problem.....
I have another D44 housing at the house i think, i might just grab that and start over....
