1,841 - 1,860 of 2,755 Posts
did you have the tmr rear support with the aluminum housing when it broke? or is that something you are adding now with the cast housing?
Discussion starter · #1,845 ·
Bringing this thing home today. Hoping it faired well during its hibernation. I haven't seen it since December. Hoping the cooling system was good to me through the cold days. Guess I should of tested it before parking it. Hoping I don't find any coolant leaks.
Discussion starter · #1,851 ·
Buggy wouldn't start. So spent the day messing with it.
Replaced distributor, relays, coil. Still no start. Well, I need to transfer the gear on the distributor from old to knew. Well my dumbass put the gear on upside down. Got that fixed. Buggy now runs. But intermittent won't start, and when acts up has no spark. Then a moment later starts and runs.
Then driving through yard, @feva4u noticed one wheel peel. Apparently I broke the rr 14b shaft at mustache run.
I have a new stand alone harness if it comes down to that
Did you figure this out yet?
Lol
