2,301 - 2,320 of 2,755 Posts
Discussion starter · #2,307 ·
Yes, that's a c6-np205 adapter. That one is aluminum, the one I will be using is steel.
Advance adapters makes a kit North of $600 to mate a 4L60 to a ford 205. I have $250 into mine so far.
We will be putting the stock vss tone ring from the donor tcase onto the tails haft of my Ford 205.
Discussion starter · #2,315 ·
Pulled the rear output housing off the 205. Slid the plastic speedo gear off. And who thunk it, the stock Silverado vss slides right on and engages the splines of the 205.
Discussion starter · #2,317 ·
Then took a carbide and removed and opened the stock vss port. Ordered a nut from McMaster Carr and welded it into the opening. Threaded the vss in and kept the vss spacing off the tone ring with a feeler gauge and tacked the nut in place. Then removed the vss and welded the nut in.
Vehicle speed sensor
While that's awesome work getting it to work, why wouldn't you just tune it out and be on your way for this application?
