2,101 - 2,120 of 2,755 Posts
Discussion starter · #2,102 ·
Hopefully not, if it takes a similar impact it should NOT fail the same way. Old setup had no protection to frontal impacts. The ram mount should help that. As well as deflect the buggy upward, instead of just hitting a wall.
Discussion starter · #2,114 ·
Seems to. I may pull it out and trim just a little. The bearing pulled tight against the knuckle and it spins. But I am concerned if the shaft is to deep in the grizzly and pressing against the cross shaft. Do a little more checking tonight before I call this part done.
Discussion starter · #2,117 ·
I need the clevis ends to build tie rods, get torque spec on ram clamps. Bleed brakes, steering, charge Struts. Install front have of driveshaft, and belly skid.
I ordered a new diff cover, a standard d60 diff cover won't work. Not sure I'll see that by the weekend though. So I may end up running the stock cover.
