2,081 - 2,100 of 2,755 Posts
As far a lockouts go, I broke Warn Premium and Tereflex lockouts. Went to Yukon and haven't broken one yet. (knock on wood) But I still carry drive flanges.
no I was looking for the cheapest thing for a buddy. also no aftermarket lockouts available for 05 and up. seems weird because these axles are super beefy surprised not much aftermarket support for them.
Discussion starter · #2,088 · (Edited)
Got majority of the parts needed today.
Got started with the truss and ram mount. Had to a fair bit of modifying to fit the larger center section, bigger tubes, and 4"shorter then the older king pin housings. But after a fair bit of cutting and grinding it all fit.
Main truss is welded on, ram mount tomorrow. Need to cap the end on the passenger side.
Discussion starter · #2,090 ·
On the bottom, yes. Not sure how it'll work out with the passenger side being changed. And this axle while the housing was narrowed 4", the wms-wms matches the 89 axle it's replacing.
The extra 4" of width is in the c's and knuckles/hubs. So it'll make mounting the Struts interesting now. I'll probably be forced to change the upper mounts as well now.
Are you gonna keep the link separation the same, top to bottom? If you do, will your lower link's be above the axle centerline? How much taller is the axle with truss that the old one? Assuming the tube diameter is so much bigger, is it gonna screw with anything?
Discussion starter · #2,093 ·
Lowers will be moved in so they'll be closer together on the axle. Separation should be close. I had to trim the truss a bit to fit it, and this truss appears a little different then the std truss.
maybe I misunderstood, but since you're moving the links inward some, can't you put the shock mounts on the backside of the axle tube? it's not ideal, but might work?
That truss doesn't look like it does much for the drivers side tube. Looks like there is a good place for improvement
Discussion starter · #2,100 ·
It doesn't, but it's also supposed to have 2 more inches of housing covering the tube.
The front ram mount also ties into that side from the front and the link in the back. My strut mount will tie the top truss into the c.
