2,061 - 2,080 of 2,755 Posts
I should get one of them gates too! I have all my gates cut out so I can go first to reverse easy
I wanted reverse to 1st unobstructed. But have Park blocked. I couldn't file my old gates to have that.
I did that to mine also but kept the nubs where the gates were so I can feel it while driving. I am going to file them down a little more though because it does get hung up on them a little.
I've had mine unobstructed for several years, also with park blocked. No issues. As far as finding neutral, I rarely feel the need for neutral and if I do I'm sitting still so it's pretty simple.
Discussion starter · #2,062 ·
Yeah wasn't concerned with neutral just want to be able to slap between 1-r and r-1 in a hurry if needed. But making sure I couldn't accidentally get Park.
Discussion starter · #2,064 ·
So I shortened the long side 4"s. The stock shaft measures 39.01“
Turns out a Chevy Dodge shaft measures 35.10". So I ordered up a yukon inner.
YGAYAW48210
Application: 1975-1980 4WD Dodge W300 1 Ton 4x4
1977-1991 4WD Chevrolet / Chevy K30/ K3500 1 Ton (4WD)
1977-1991 4WD GMC K35/K3500 1 Ton (4WD)
1981-1993 4WD Dodge W250 3/4 Ton 4x4
1981-1993 4WD Dodge W350 1 Ton 4x4
"should" fit. Be sweet if it did. Won't need custom shafts.
What are you gonna run for stub shafts and drive flanges. I looked and couldn't find anything other than stock stubs. Brian broke the stock lockouts and we got drive flanges from rock solid but I think they closed up shop?
Discussion starter · #2,067 ·
Yep, stock for labor day club comp unless I find something before then. Haven't had any luck finding flanges yet.
For now, stock stubs and stock short inner and yukon inner long side. Spicer joints and full circle clips.
Rcv eventually.
Yea rcv were pricey for super 60 way more expensive than normal 60 rcv. I don't see the point with stock lockouts though they will be first to go. I might be able to get some drive flanges cut if you need them
Discussion starter · #2,076 ·
SO, it looks like CTM has made 1550 stub shafts and 40 spline inners for these 05+ unit bearing knuckles, that spline directly into the HUGE spline drive of the bearing itself.... basically since they came out... 10 years ago.
WTF. Why has this not caught on, and why do people even mess with 40 spline 1480 kingpin stuff!?!
These pics are from 06/07...
:nana:
