661 - 680 of 994 Posts
Johnny, have you thought about drainage? Seems like a solid plate like that may hold water and dirt pretty well
Sent from my SM-G996U using Tapatalk
Discussion starter · #669 ·
Made a mount for the trans cooler. Have some fittings on order to put 90* AN6 fitting out the top. Once the fittings are here I will adjust to final position and make it bolt in. Looks like it all fits. This took a while to package all of it, but I’m happy it’s all there.
279573
279574
Before you do anything throw a coilover in there with a spring and cycle the axle both ways to see how much room you'll have. Hard to tell what angle they're canted out at but my adjustment on the top of my coilovers make contact if they're too high based upon the angle. The shock towers are mounted in mine.
Discussion starter · #677 ·
Those wobbly sharpy marks are where the air shock is at worst case (driver's side full droop, pass side full compress). I have about 1" between shock body and the shock mount. That is one reason I'm a bit worried to box it back in, but I think I can make it work.
