Any tricks for opening a locked (rollaway) toolbox?
1 reading
60K views 19 replies 17 participants last post by  buddha
#1 ·
We got a big rollaway at work from out Huntsville, AL location which we are closing out. Keys are with it, but the thing won't open (I think I got the bottom box open, but the top box is stuck or still locked. Key turns but doesn't open.
Any ideas?
#8 ·
what brand of box? most of the bigger names (Snap On, Mac, etc) use a drop bar at the back of the box, so turning the box upside down, or close to it, will unlock it...if you can get one drawer opened, then you can pull that drawer out all the way, reach to the back, and lift the drop bar by hand...
you can also pull one drawer open as you slam the other shut, as long as you open the locked drawer at the same time the open drawer lifts the lcok bar...
#12 ·
Hey if you want you can always drill out the lock which sucks, but you wont damage the box and the lock sets is only a few bucks. Good luck:thumb:
X2 I've done this a few times.
#16 ·
it all depends on the box. a lot of matco boxes can be opened with a flat 1/8 about 2-4 inches wide piece of metal long enough to reach the back of the box and pushing the right ways.
other boxes there is sometimes releases you have to do even with lock cly. unlocked.
don't cut it up there is always a way. pics and brand of box might help.
we have at least 100-200 boxes in our shop and there is always people leaving their keys at home and we have to find ways into them.
a tool dealer also can help you out if you can talk to them.
#19 ·
If it has a flat top pull the pad or board off the work bench area. In the back there will be a rivited plate. Drill the plates and lift the locking mechanisims
