81 - 100 of 117 Posts
Discussion starter · #82 ·
Your rat rod looks really cool.
Thank! Been a dream car to build for a long time. Picked the body up last year and slowly been collecting parts. It’s a roller for now. Need to make a nicer frame for the back connect the body plan to build a cage for the whole thing. Plan is twin turbo coyote in it.
So it's going to be like a sleeper that burns lots of rubber.
Can't wait to see your progress.
Discussion starter · #84 · (Edited)
Made a hole for the pcm last night. Also found a spot for my fuse box it’s crooked and I need to move it over so it will sit better but it’s Time to start re routing and shortening wires!
Discussion starter · #85 ·
Picked up a few parts last night for set of 4 coil overs and 4 bumps.
Next weekend I’m picking up a set of 48” trailing arms so I’m a few more parts
Closer to linking my bronco!
Discussion starter · #96 ·
Fuse box is done ish I’m sure I will need to add a few more wires but I hooked power to it and the switch pro lit up so that’s some progress
Discussion starter · #100 ·
Cut the rear quarter open to test fit for 37’s
pulled the gen 1 Coyote out.
Replaced it with the gen 2
Gen 2 wiring is simpler and cleaner. I also got Eric and hp tuners to add a patch so anyone with ho tuners can unlock a gen 2 or gen 3 pcm.
