1 - 16 of 16 Posts
Eye candy
I'll put this in general.
Today i parked my Samurai in my driveway, which has a hill, Put it in 1st gear and the little bugger started to roll backwards down the hill slowly. You could feel it pulsate with with i assume was engine compression. Which would have been rotating in the direction it shouldn't. Never had this problem before, doesn't seem to do it in reverse.
so, is my trans fuXoreD, Clutch being heavily worn, or i should just stop parking on hills
Ranger Addiction?
My parking brakes work great forward, not so much in reverse, border-lining not at all. Hence I do depend on mine being in gear (though it's a Ranger)
I'm not so sure it's the trans thats doing it, as the forces are getting all the way to the engine (chugging with compression strokes). my first guess is a compression check, maybe worn valves or rings, etc. Low compression = easy to turn
Reverse is (usually) a lower gear than first, which would be why first could roll more easily..
Eye candy
Discussion Starter · #7 ·
:stan:
1st 3.652
2nd 1.947
3rd 1.423
4th 1.000
5th 0.795
Reverse 3.466
Uggh
put a cinderblock behind the tire
Support the Sport!
I put mine in 4 low on my drive to keep it from rolling
Eye candy
Discussion Starter · #15 ·
transmission isnt meant to hold a vehicle parked .. thats why there are PARKING BRAKES.. (if it doesnt work.. FIX IT) ..
It works, Now STFU :sonicjay:
Eye candy
Discussion Starter · #16 ·
on a related note, i did check compression and got these numbers with the engine cold
1-120 psi
2- 135 psi
3- 145 psi
4- 130 psi
after i added oil to the cylinders
1- 140
2- 145
3- 175
4- 160
Meh, it runs
1 - 16 of 16 Posts
