1 - 20 of 91 Posts
Premium Member
Getting closer. Should be done by CR.
93 YJ tub, frame & 2.5 (engine moved up and over 7"/2")
94 904 w/ manual valve body
J-truck 208 w/ factory fixed yoke
3-link front w/ QA1 heims and +2 cherokee coils
Spring over rear w/ extra main leaf
CJ front clip (shortened grille)
HP 44 front w/ Yukon chromoly shafts & Superjoints
9" rear, S10/CJ7 discs
5.13's, welded/mini spool
37" Truxus'
Done for under $1000 ($940 so far), thanks to too many members to list for parts donations and all-around good deals.
for a minute there I thought you stole my trailer. It is the exact same make/style
looks good
i like jungle gym's.
you working on it again? looking good scott, you have a month!!!
Support the Sport!
is that an S&W racecars cage?
Did you put it together?
Was is nicely made?
Hack
It's nice to have a network of people to help out....
Hell, it's tough to get a good meal for 8 people under $1000...Life's too short to drink cheap booze....
Premium Member
Discussion Starter · #13 · (Edited)
Brakes consist of 80ish CJ front rotors, and 83-92ish S10 calipers.
I have the template for the caliper bracket and can bring it to the pig gig if you want to trace it. The outside edge of the axle shaft flandge must be ground down 1/8" for the rotors to slip all the way on, but this gives you an idea. S10 calipers are $7 each, and the pads are $10/pr.
Simplify...
Getting closer. Should be done by PG.
35" BFG's
Very cool idea, and nice work! If you need any little CJ-ish parts to wrap it up, let me know. I can't believe you've done it so inexpensively! :thumb:
Craig
1 - 20 of 91 Posts
