^^^^^^ Thanks for sharing. While I knew you were supposed to set them up parallel, this explained it all very well.
My np205 makes the same noise when I let off and coastIs that when you are backing off and coasting? If so, that's pretty common with an Atlas. The gears just sorta rattle against each other.
Mine does too and I hate it. I'm gonna change out the rear bearing which is a little sloppy to see if it helps.My np205 makes the same noise when I let off and coast
Sent from my SM-G996U using Tapatalk
.... Maybe....At least the u-joint should live longer now!
there are a few issues…. First being 1410 stuff is crazy expensive for a CV. Secondly, the driveshafts I’m using are 1/4” wall and am not sure I can find a CV that will slip inside the tube.That video is the concept of why I used a cv. My junk is not as built as yours (5.3,4l60e,np231/sye,D44hp&nine), so I used what was popular back then. I found a used xj front driveshaft and incorporated it into my rear driveshaft build. Could you use a one ton driveshaft and incorporate that into yours? Then you just point the rear axle strait towards your t-case if I remember correctly.
Its a learning experience. I'd say overall your build has turned out really well with limited issues. Always going to be a few bugs to work out. You've got this!i Hate this stuff 😂
Thanks! I’m pretty happy overall with the build. Few small issues. It could have totally been worse! Having built it so many different times I kind of knew key things to look out for. That’s proved to help!Its a learning experience. I'd say overall your build has turned out really well with limited issues. Always going to be a few bugs to work out. You've got this!
