If I'm doing heavy milling I will use a collet. But if I'm just slotting a hole or squaring something up, a chuck works fine.Plato2k5 = Good stuff! So I just need to get an assortment of R8 collets and go on a buying spree. Is it worth buying the premium brand collets or will cheap ones from amazon do?
Just cheap collets should be fine for what you are doing. If you want to do some tight tolerance stuff it might be a problem, but not likely...
Good advice. But I do not put end mills in chucks, just not ridged enough in my opinion and chucks are not designed to work under a side load.....
