1 - 20 of 22 Posts
· Registered
93 XJ, I recently purchased this. The previous owner had pulled the motor out and thought the bearing in the lower end was bad. It was only the flywheel. They reinstalled it. It will not fire. Does have fuel. Changed the crank senor (under the rotor in the distrib), crank position senor on the trans housing. Cranks over fine but does not fire. Owner said dist. was not pulled when motor removed. Help!!
· Registered
I changed the flex plate on my wife's 2000 xj and having the same problems. You find anything out post it up. For me everything is checking out , fuel pressure is at specs. It ran after I put everthing together and slowly shut down as it was running to the point where it's a crank no start.
· ROLLIN'---RUN IT:)
Had 89 do somewhat of the same thing and it ended up being the computer. Double check all your wiring connections could be something as simple as a wire not hooked up or one hooked up incorrectly. Good luck:bdr2:
· Registered
should of asked this sooner , are you sure they installed the right flexplate (flywheel) ?? The crank position sensor reads off the flexplate, which in return controls your spark to fire the engine. I would check the persons work you got it from first.
· For Sale: AMC 360ci v8
If the PCM isn't grounded then you'll hear a really fast clicking from the ASD relay. You'll get fuel pressure @ the rail but a pulse signals won't be sent to the injectors, that's why I asked if the plugs were wet with fuel.
The plugs are wet. The ADS relay clicks fast, when key is on before you start it.
looks like someone has some checking to do. Hopefully that's all it needs.:naughty:
1 - 20 of 22 Posts
