1 - 13 of 13 Posts
Nut up or Shut up
Ok I have the bastard packs and shackles for the rear and 3" springs and 2" spaces as well as adjustable LCA's for the front. Also have longer brake lines. For now I plan on doing a T-case drop(need to know how much to drop) and is there anything else I need to address? I know I need to do a SYE but I have to wiat till June for that. Thanks
Nut up or Shut up
Discussion Starter · #4 ·
Ok wasnt sure about trackbar. What about steering? Tell me more please.
I already have adjustable LCA's.
I'm just over 5 inches on the rear on my 96 xj and haven't had to go to a sye . going to need a drop pitman arm pick up one for a zj it will give you a 1 inch drop . going to need a adj. trac bar too. t-case drop is 1 inch
Nut up or Shut up
Discussion Starter · #6 ·
TY TY didnt even think about pitman arm. Guess now I have to find a cheap used trac bar.
T-case drop can be 1"x1" tube right?
rc adjustable trac bar you can find for under 100 bucks Take a look at car parts .com
should put that you would trade your rims for and list some of the stuff your looking for just an idea
you don't have to necessarily have to run a drop pit man arm. Just need to insure your track bar and drag link are close to running even, as to avoid death wobble. Stock steering is rough running on a 4.5"+ lift, it needs some beef, an older steering setup you will feel the weakened state of it when you lift it. Rugged ridge as a nice little set up for Like $179 that is a good upgrade. Also, seen it done several times on a 4.5" lift is the V8 ZJ steering upgrade. Just like the stock steering you got now but much beefier and very noticeable once installed. For the track bar, I went with the rough country set up for less then $100 and gives you room to go to 6.5" of lift. And I ended up getting mine through JCWhitney and it was cheaper than RC.
http://www.jcwhitney.com/ROUGH-COUN...0208_N_111+1994+200728794+600003409_10101.jcw
1 - 13 of 13 Posts
