1 - 3 of 3 Posts
On the bolt closest to the middle of the vehicle, the one that bolts the leaf spring into the frame, I can't get out. It just keeps spinning. I tried prying it but it still won't work. Any ideas?
cut a hole in the floor. put a wrench on the broken weld-nut. get the bolt out. buy a new nut. replace springs and bolt. tack the nut to the inside of the frame rail. patch the small hole you just cut in your floor.
Discussion Starter · #3 ·
The thing is, it looks as though the bolt is still coming out, but the collar of the leaf bushing is spinning with the bolt itself.
1 - 3 of 3 Posts
