1 - 13 of 13 Posts
  • Need a set of front shocks for an XJ(eyelet or bar pin to stud), needs to be roughly 30" extended. Don't need to be brand new, but I don't want junk. The cheaper the better.
  • Some kind of extended front brake lines if you've got them lying around, the longer the better.
  • And two 1"-2" poly coil spacers, color is irrelevant. -Got 'em
Kitten I'm gonna eat you!
I got a set of coil spacers if you have spring compressors at pig gig you can get them from me.
Wrenchin for a livin
Got a pair from a 6" xj lift.
# on shock is n8059s.
Measure about 29" to bushing surface.
Will need new bushings.
$10 each.
pm or call 989.860.1052
1 - 13 of 13 Posts
