1 - 6 of 6 Posts
I'm looking for a set of bright off-road lights with mounting brackets. I don't need the harness, just the lights, but if you have the harness I would take it. 55W or 100W doesn't matter. Plastic casing or steel is fine, but if they're steel, I don't want a set that's all rusted! I would also prefer square lights, but round will work too! $50 range would be nice. Let me know, thanks!
Buy some Hella's. Round, composite housing, brackets, wiring, covers all for $39.99 plus shipping. Amazon.com
I have two sets on the jeep. Both are wired into my bright lights. When it gets warmer, I will also make'em come on with a switch.
Mall Crawler
x2 on the hellas. For the money and wattage, they are excellent. Tight crisp brilliant white beam. And they also come with a relay and harness, so at $40, its a hell of a deal.
Ive had mine on for 6 months or so; theyve been hit with stones on the highway, submerged in water, and are turned on almost every time Im out after dark. Zero problems.
Mall Crawler
Also sold at wally world for likr 50-60 bux
I got mine at advance for $60. :thumb:
The walmart ones are like $10 cheaper than everywhere else, but the wire harness and relay arent as good.
From what I hear, there are 3 versions of the hella 500 kit. The $40-$50 walmart version, the $60 everywhere else version, and a $90 version you have to order. The lights themselves are the same, but the wire harnesses vary in quality and how much assembly is required.
1 - 6 of 6 Posts
