1 - 16 of 16 Posts
MM 10,500 lbs Hydraulic winches and valve kit. Used 4 time 2 load rolling truck on trailer and pull 2 4x4 post from yard. $800.00
Part Number 70-50050C
Rated Line Pull 10,500 [email protected] PSI
(single line) (4,770 kgs.)
Gear Train Planetary
Gear Ratio 6:1 (low gear)
1:1 (high gear)
Motor 17.9 C.I. Hydraulic
Cable 3/8" x 100' (14,400 nominal)
Drum Size Diameter 2.5" (6.4cm)
Drum Size Length 9" (23cm)
Total Shipping Weight 93 lbs.
Bolt Pattern 10" x 4.5" (4 bolts, 3/8")
1 - 16 of 16 Posts
