1 - 3 of 3 Posts
NMU Trailcat Alumni
dunno if this is true for sure, but i'm pretty sure i read some where a zj block will work but a wj won't due where the motor mounts bolt to the block. also the head from a wj would have spots for the coil packs to bolt on but u'd be using ur distributor so that wouldn't affect u i guess. a renix motor also has a knock sensor, i believe on the drivers side near the bottom of the block, i think but am not for that u'd be able to thread that into any other jeep line 6 block though.
basically no it won't and that should be why
1 - 3 of 3 Posts
