1 - 20 of 25 Posts
Last Free Man
I'm looking for a winch for my scrambler.
There are two that I'm contemplating right now:
1. old Warn 8274 - 8,000# (I can get this one and a Ramsey 6000# for $400)
2. newer Warn 12,000# ($600)
I like the 8274 but I'm concerned if it will be enough pulling force for a scrambler.
Last Free Man
Discussion Starter · #2 ·
bump for morning crowd, in case you weren't awake at midnight :)
F-U-CANCER!!!
For original purchaser. Not sure if it covers the break??
How heavy will the scrambler be (tons and 40's or???)?
88
CC is right Warn parts are expensive. I use 8274's with 2 batt's, 00 cable & my only problem with the winches has been the brake system. $.02
Last Free Man
Discussion Starter · #7 ·
I'm thinking when it's all done, it should be around 6,000lbs.? Doesn't it weight around 4k when stock?
I have rarely seen someone who actually owned an used an M8274 that wanted to go to something else...
Premium Member
Have had a few different winches and now run an 8274. Like Haggar said, will never run something else. Maintain it and it works well, just like anything else.
Never had a bit of trouble with it.
HURL SCOUTS
I have always owned ramsey winches. but the new solid state milemarker v10 & v12 look nice.
I have a Warn M8000 on my scrambler, seems to be large enough. Is the winch for self recovery, or are you a trail guide type and will be the official wincher? If the later get a larger winch so that you can run it longer between cool down periods.
i like jungle gym's.
i used mine for 2 years and i sold it.great winch but not enough power.i was going to do the bigger motor but i decided to off it and get something else.want something smaller in size with more power.the ground is real touchy on it also.
a little birdy said call ironman, i think there is a couple good deals on tmax's to be had.jeepbratt just got hooked up from him.
My 8274 is over 30 years old, I can only remember one time I had to double up the line for self extraction, I tripple lined a tractor out of a pond once as well. It is enough winch.
the 12000 is sllloooowwwww compared to the 8274.
8274 - great winch. nice and fast and reliable. i had one that was 25 years old. a quick once-through and it was good to go
Premium Member
8274.
Have 4 of them now. And a HS9500 on the TJ.
can you hear the banjos?
your going to give me one right?
i'll trade you... well, besides the usual "favors" and paintball equipment i have some motors and other parts laying around :)
any parts to bump up my compression on my mullet ride?
Premium Member
Nope. My Scrambler weighed 3200lb with a small block Chrysler in it and an 8274 on it.
1 - 20 of 25 Posts
