1 - 6 of 6 Posts
· no wait! my name is joe
does any body weld the axle tubes to the carrier, or is that not an issue with the dana 30. (btw its out of a 93 yj with the stock disco) should i weld the tubes into the stupid thing that houses the disco too?
another slightly off topic question if i want upgrade to a one piece shaft on the pass side, can i use one from the junkyard out of a cherokee/ grand cherokee with out changing the seal in the diff? recomendations on the CHEAP would be appreciated!
· Covered in mud...
I don't know that I've seen people spinning the pumpkin on dana 30s. Its actually pretty hard to weld it anyway, you'll think you are good, but, come back in an hour and your welds will likely have cracked loose anyway.
I believe you'll need a new seal that goes inside the axle tube for that long size. There's and OEM one that fits, even though there's no machined surface.
1 - 6 of 6 Posts
