anyone in the traverse city area have knowledge of putting a weber on the I6 258 cj7. I would galdy provide some food and beers to come help me out for a bit. With the stock intake manifold, and aftermarket dual exhaust header is it better to
1. plug the pcv connection at the base of the carb adapter plate or????
2. eliminate vacuumn assembly on the wheel well side of the carb that has 3 connections, 1 to brake booster, 2 to charcoal canister, and 3rd is plugged and just run 1 vacuum into carb from brake housing.
3. the vacuum advance to the distrubor is a small house that attaches to a adapter on intake manifold with a second line running to charcoal canister.?????????????? how, where????????????? to run this.
Jeep starts right up and drives great when cold but when it gets warm, it'll lag under a heavier foot and sometimes sputter. I have a fuel regulator set at 2.6psi between the fuel filter and the carb. primary jet is one turn out as per tuning instructions from weber and bowl moves freely and adjusted to 17.5mm. I'm just missing the final tweak and could use a hand
