1 - 4 of 4 Posts
the 1999 TJ gets a very wet passenger side front floor carpet after a heavy rain. is there a likely place to look for a leak in the cowl or front window? it's not the door nor window seals.
thank you
Premium Member
Pull the cowl off and check the drains.....often get plugged and then the water will come in the HVAC
bdd
No need to pull the cowl unless the drain is plugged. Open the hood and locate the rubber drain thing directly behind the cylinder head. Poor a cup of water in the cowl and see if it drains quickly.
1 - 4 of 4 Posts
