1 - 15 of 15 Posts
TRLR8TD
i need a rear drive shaft with or without u joints for a 1981 or similar cj5 asap
located in commerce so somewhat close:woot:
248 229 4269
TRLR8TD
Discussion Starter · #5 ·
no sure what trans its a 4 spd , length is approx 14 inches
TRLR8TD
Discussion Starter · #7 ·
no one has a extra drive shaft sitting around in the garage?:confused:
Premium Member
14" is that running length? Approximately 14" I am sure that I have a couple in that area but it makes a difference on what position it is being measured in.
TRLR8TD
Discussion Starter · #10 ·
yeah 14" is yoke to yoke, it has to be smaller than 14" because of travel
Jeep CJ Addict
HI,
Just because you mentioned it is about 14" I thought I would let you know I have this one which is about 14.25 as it sits. Might collapse a little more if the grease was forced out. Joints are good and it is tight enough. If it will help you, $40. shipped. I assume you took your measeurment with the tires on the ground? Is your transmission mount good (if the trans goes up, it would take more length). Also, eliminating a drop trans crossmeember kit would do the same but would increase angle.
Rudy
614-203-1947
1 - 15 of 15 Posts
