1 - 20 of 27 Posts
Premium Member
Hi. I have a supercharger that I will not be using. It is a Vortech V1 mounted to a SBC mount along with a saginaw power steering pump. This has a 3" pulley on it, and should deliver 7-9 lb's of boost through 6000 rpm on a 350 CI engine. Of corse it can be adapted to anything you want, but right now it is setup for a SBC. Oil lines for unit and return are included, but crank pulley and belt are not. $750
im pretty much dumb as hell... what would be required to adapt it to a 96-98 Chevy vortec engine? Does this have a part # or anything for idenificaiton purposes? PM me prease!
Premium Member
Discussion Starter · #3 ·
A Vortec 350 would love this. You would need a crank pulley, belt and some tubing/pipework to connect the outlet to your intake. A K&N filter can be mounted directly to the Intake of the unit, or more piping can be used to move the filter into the cab.
Premium Member
Discussion Starter · #4 ·
This is a 700cfm unit and is intended to support 480hp. (ideally, it takes your 300hp engine and makes up to 480).
AKA GreyShrink
I have a Vortec 5.3 with that "active fuel management" in my 2007 Trailblazer. Would there be any problems fitting it to that?
Im going FAST!!!
MMMMMMMM I have been eying that thing in your garage for a while........
I have to look and see how hard that would be to hook up to my 302.
Premium Member
Discussion Starter · #7 ·
Im sure the fuel managment could keep up, but you would have to buy or make a different mounting plate for your Gen 3 engine.
F-U-CANCER!!!
Any good sources of info for installing these. I would be installing with either a carb or tbi (amc motor)??
Premium Member
Discussion Starter · #10 ·
TBI would be easy. To run a carb you would have to buy one of the pressure boxes that completely encloses the carburator.
Im going FAST!!!
I have to look and see how I could fit this in the buggy, it is really tight.
But I need it. Is it at your house I may have to stop by this weekend if I go to woodward and see how big it is and how I can make it fit.
You have to have a different crank pully because the belt is bigger than the factory belt correct????
hmm. Was this run on a carb'd sb before correct? Looks as if the mounting brackets/everything besides the 'blower' itself would be kinda usefull for my application.. but i still wants it :( No part # on the blower itself? I highly doubt they would sell all the individual pieces to set it up.. me=sol
Im going FAST!!!
If I buy it I wont need the brackets because I would put it on a 302. I could sell them to you
Premium Member
Discussion Starter · #14 ·
Dana I will be at Hosejockeys house all day Sunday and can bring it if you want to check it out.
I currently have 2 out-of-state bidders on one of the musclecar forums I frequent, but I really don't want to ship. (I haven't answered their PM's yet, hoping for something local).
Im going FAST!!!
Would I have to change injectors????
Let me know what time in the AM you are going there I can probably stop by to check it out. I may drive the buggy there so you can see how tight it is.
PM me your #
Premium Member
Discussion Starter · #17 ·
Dana, number is 313 657 4344, and I will be ay caseya at 8. Mudtruck, I will be amazed if it lasts through the weekend. This is less than 1/4 the price for a new one and this only has an hour of run time on it.
Im going FAST!!!
ok Scott I am OUT I just went out in the garage and looked at how much room I have their is NO way that thing is fitting. :(
BTT for bad ass SC
1 - 20 of 27 Posts
