Ok, when comparing a 4.3 to a 350, is it the front 2 cylinders lopped off or is it the back 2 cylinders lopped off?
Wondering if doing the swap moves the trans if you use the stock motor mounts.
Also....if you were going to hook a 4.3 to a th350....what flex plate would you use...the one from a 350 v8 or the one from the 4.3?
