1 - 9 of 9 Posts
Ok so I think that I might have made a really big goof when I put my 360 back together
while trying to get it started for the first time sice I ve put it in the YJ It was popping through the carb and not runnung just right
I chechecked my firing order twice then I rset number one to TDC and cheked to make sure that the roter in the dist was pointing at nuber one and it was but it still dont wanna run it runs like crap
the only things that I can think of are
A) the firing order on the cap should be counter clock wise (Ive got mine clockwise
or B) When I put the cam in and lined up the dots on the gears I had number 2 cyl at TDC like an idiot
if A than thats not so bad easy fix
If B what can I do can I just reorder the wires on the cap or do I have to pull the front off the moter again
how can I check this without pulling everything apart again???
Hey James,
Pull the plug and stick your figure on the hole. Crank over a few turns till it blows on ya - make sure that its TDC and on the right stroke otherwise it'll be causing you alot of troubles.
Just a couple weeks ago, i put in my HEI and had the firing order the opposite direction. What a goof ball - i know - but the reason it took so long to figure out is that it actually ran just not really good. Thats right - it ran in the complete opposite order but would quickly die out. I was pretty amazed nonetheless and spent time tuning the carb and the timing till i noticed it.
Premium Member
If you lined up the cam with #2 at TDC instead of #1, you will need to pull apart the front of the motor again. You do know the driver;s side bank is the odd nubers, correct?? If so, which side did you line up as #1?
Discussion Starter · #6 ·
Yup I know that one side is odds and one is evens
Im sure that i used the driverside as number one but I can think of anything else that would make it run the way it is
Im gonna check out a few other things and if it all checks out I gues Ill have to pull thefront of the moter apart and make sure its right
A pirate 200 yrs to late
Vacume leaks will make the motor run like shit. Check all the ports on the manifold and on the carb. Took me a while run all of em down on mine. Also timing if very critical. Set your timing to 12 degrees before tdc with the vacume advance disconnected and blocked. Popping through the carb usually means the timing is advanced to far.
1 - 9 of 9 Posts
