1 - 12 of 12 Posts
Glad I'm not Gay J. Hall!
how hard is it to replace the u-joints on the front axle of an xj, not the drive shaft!
Not that hard. Hardest part is getting the hub off. Then, if you have ever done a driveshaft u-joint, it is pretty much the same
Discussion Starter · #3 ·
yeah i've done drive shafts, just wasn't sure how much i had to tear apart to get it apart
Mine were fairly easy. A press does help though, a whole lot quicker.
If you have a torch, utilize it when doing the ujoints. You will more than likely have to anyway.
Premium Member
One of the best investments I made was to get the harbor freight ball joint/u-joint tool. Makes life alot easier if you don't have access to a press.
The really rusty ones a put alot of tension on a tap the yoke and it usually pops free.
6'-5" 209LB 16YR LEFTWING
Took me an hour and a half, to do both sides, on my XJ and I'm a Ford guy.
The bearing is remarkably similar to the design of the d60 on my 1 ton Ford, just smaller.
1 - 12 of 12 Posts
