Thanks, I called the zone, they are blaming it on a faulty gas cap, of course.....should be OBD II
IIRC all OBD II codes are the same
P0456 is usually a small leak, where the system can draw a vacuum, but not sustain it. Like the cap is not tight.I've frequently gotten gas cap errors on my 2001 WJ
Tell us the code as it is OBD II, and as that list states the codes you posted will work for jeeps up to 97
if it's a PO456 its most likely gas cap....
http://wjjeeps.com/faultcodes.htm#0400
list of codes
Those codes say the same thing that the 'zone did. I will try a different gas cap, look for possible leaks etc. And continue to ignore it.I've frequently gotten gas cap errors on my 2001 WJ
list of codes
