1 - 4 of 4 Posts
used to be Ironman
Discussion Starter · #3 ·
2005-09 TOYOTA TACOMA 4WD/2WD
3" UPPER CONTROL ARMS & COILOVER SYSTEM
Obtain increased height and wheel travel for late model 4WD/2WD Tacoma’s with Fabtech’s Upper Control Arm systems. The tubular Upper Control Arms feature 1.25” OD, .120” wall thick chromoly tube construction with 1” diameter Teflon lined uniballs that attach to the factory spindle without drilling. The replacement UCA's have been designed to work in conjunction with Fabtech’s Dirt Logic 2.5 Coilover shocks providing 10” of wheel travel for a complete front suspension system upgrade. Vehicle offroad suspension performance will be greatly increased due to the extensive ride tuning of the Dirt Logic 2.5 Coilovers and rear Dirt Logic 2.25’s. The stance of the vehicle will become level as compared to stock and will provide additional clearance for oversized tires.
used to be Ironman
Discussion Starter · #4 ·
This is the 94.5 - 04 kit
1995.5-2004 6" PERFORMANCE SYSTEM
Our 6” Performance System features specially valved extended length front shocks that utilize the stock coil springs for a factory like ride. Massive extended length cast steering knuckles attach to high arched lower control arm crossmembers for superior strength. A 1/4” thick steel skid plate protects the front differential. Included in this system includes preinstalled wheel bearings, seals and ball joints for a quick installation.
1 - 4 of 4 Posts
