1 - 6 of 6 Posts
Live Action!
I have seached but my question is should the TJ be getting more than slightly warmer than the outside air?
I have been doing mostly highway driving and would like more heat.
It does blow warm/hot heat but the cab doesnt get very warm.
I am comparing this to my 2003 Sierra that gets plenty warm.
Maybe the Jeep leaks more air?
Can't Worry About It
your jeep should get nice and toasty inside.
what year is your jeep? engine? what kind of top? doors?
my stock 04 gets warm inside, but it normally takes a while to get the entire cab hot like at least 15-20 minutes of driving. but keeping the heat vented at the floor only the cab never gets hot.
obviously the jeep leaks plenty of air and lacks insulation to keep the heat in so its never going to compare to your sierra, but you shouldn't be freezing either
Small, but talented
Check the knob for the heat selector. Mine cracked and the metal insert spun a bit. When the dial was at full heat, luke warm air was coming out. The TJ heater should cook you.
Live Action!
Discussion Starter · #5 ·
It is a 97 4.0 hard top w/ full hard doors.
Live Action!
Discussion Starter · #6 ·
I already know that the heat selector does not work properly, but I can manualy adjust it for cold or heat. I have it on heat.
I get warm air just not enough to heat the cab without driving for a half hour or more.
1 - 6 of 6 Posts
