21 - 40 of 53 Posts
Gustafson
Same can of worms with my 2010 Sierra. Replaced bumper, found out hitch was rotten. Replace hitch, noticed rear shocks were bad. Tried to replace shocks and spare tire winch was seized. Cut off tire winch and replaced shocks. Decided while i was there to change rear end lube, all cover bolts so rusted they were no longer bolt heads. wtf. :whiz:
:( I heard this can be an issue. I have a 2013 Sierra, I should probably check mine.
Discussion Starter · #24 ·
That is either a stripper pole or one hell of a drive shaft :teehee:
Shaft it is.
After years and years of abuse it was time for that big bitch to go :finger: I am done with putting carrier bearings in this thing, this new shaft is 26 Lbs lighter than the old one and the u-joints are stepped up to the 1480 also :woot:
The girth of this shaft is impressive :teehee:
RBB
Discussion Starter · #26 ·
My truck is a 04 quad cab long bed, in 07 the mega cab short bed trucks started running a OEM one piece drive shafts. After doing some research the trucks are identical from the frame down, and the OEM part number was not hard to find. I talked to 2 different shaft shops they could make it but it would have a 90 mph max and cost me a grand, :( I got this one shipped to my door for around $550. Just for fun I kick the big pig this morning on I94 and she ran 105 as smooth as a 15 year old truck can. :woot:
RBB
Discussion Starter · #29 ·
I just got back from a wheeling trip and knew some maintenance was going to be needed. So, I grabbed some oil and decided to check up on everything as my front rims had break dust all over them. Upon further inspection the front breaks were fine but the back ones were toast. I had a seized up rear caliper that ate my pad during our long drive home. So it was that game of phone a friend to get a ride to A Zone for parts and get it back on the road before work tomorrow.
RBB
Discussion Starter · #31 ·
I knew it was on its way out but I thought if I babied it along it would hold up but this morning I had no 2nd gear for my drive to work there goes another 3k:( to the up side the tranny shop can start on it tomorrow :rock:
RBB
Gustafson
RBB
How many transmissions has this truck had? Doesn't it have an ungodly amount of miles on it? Glad to hear you can get it fixed quickly.
Gustafson
21 - 40 of 53 Posts
