Had to put together a parts list for the new owner tonight.
1997 Dakota
1988 F-350 front axle housing
Reid knuckles
Metrofab high steer
Surplus Center Ram
Custom hydro hoses
RCV axle shafts
5:38 gears
Full spool
1999 Dodge Ram 360
M1 intake
Shaved deck
Shaved heads
Custom porting
Custom ported throttle body
Custom tuned by Flyin Ryan Performance
Mopar 727 Transmission
Full manual valve body
Adapter to Tcase from Advanced adapters
Art carr shifter
Ford 205 Tcase
Twin sticks
JB Conversions cable shifters
1410 driveshafts
Front has a carrier bearing that uses a D60 pinion and yoke
14 Bolt
5:38 gears
Full Spool
Stock shafts
Fuel system
Custom lines
Stock 1997 Dakota tank
Smitty built winch with in cab hard wired controller
Amazon special boat switch panel
Fans | Ignition | Cig Lighter| Interior light | Front LED Bar | Rock Lights | Siren | Fuel pump
Fuel pump switch stays on and is powered by the ignition switch
