1 - 5 of 5 Posts
Does anyone run these on a TJ. I put mine one plus did a couple other things like new tie rod ends and now i get a jingle noise above 45-50 and up to as high as 70. It sounds like the end of a chains dragging on the ground.
What i did the same day before the noise came on.
Front pinion seal
New tie rod and drag link
Sway bar disconnects.
Everything appears to be tight.
Only thing i haven't tried is disconnecting then driving. I think it may be the disconnect pins.
Help
ASSHOLE
I have tera discos on an xj and they are rattley as hell. Do you use the washers? No washers is a bit less rattley..
1 - 5 of 5 Posts
