Very nice. I love seeing a TDI motors being used in other vehicles. I know someone that is having one drop into a CJ7.
I've done lots of engine swaps and ridden in many. For a sub 5000lb vehicle, I don't think there's a better bang for the buck diesel option in terms of weight, performance, and overall cost. If you're gas swapping, then an ls I'd say is king, but everyone already knows that
Hydraulic winch is fully operational and I already had it use it to pull a dead vehicle up an iced over 8% grade driveway. As expected, line speed isn't raging fast, but I know I can pull all day and now have a baseline speed to make power steering pump modifications against.
Tig'ed on some 6an fittings
Ran a switch in the cab so I don't have to use the remote sitting in the truck. I'll get a nice switch the next time I order from McMaster, this was a super cheapie I had laying around.
Cooler plumbed up
Filter
Hooked to a tree and spooled the line on in high gear as a test. This line is ugly towards the bottom so I hit up ebay for some 7/16" synthetic line and a hawse fairlead that will be here next week.
I took apart a spare vw pump to see what the guts of the regulator look like. Holy hell the flow passage in the outlet fitting is small haha. I cut the pin off the pressure piston that protruded into the orifice and use some small carbides to give a better flow path than the two tiny notches that were there from the factory. I'll add the 2 washers under the spring to bump the pressure. I have a pressure gauge I'll hook up to check outlet pressure after the mods.
Stock
Mod attempt #1
