Yes, I'm using the ranger trans to make the swap as simple as possible. Absolute cheapest way to bolt a tdi to a rwd trans is http://tditoyota.com/products/tdi-engine-adapter-plate-for-toyota-22r-bell-housing . I don't know squat about 4 cylinder yota tranmissions as to how much TQ they'll handle so I can't offer a comment there.So are you using the ranger trans? Friend of mine is wanting to put a vw diesel in a flatfender jeep. Trying to find the cheapest and easiest trans to put behind one.
It's getting there! Killing time till adapter kit gets here :rock:.Very nice work, great job :thumb:
And the timing is perfect as the ford 3.slow is running on 4 cylinders on a good day LOL. It's had a blown headgasket since I bought it and it's getting reallyyyyyy bad now. This is my work truck so I can't afford to have it down any longer than absolutely necessary. The plan is to have it back on the road in 7-10 days. I think it's doable since I have everything but a few yet to be known size/shape silicone couplers here.Awesome that this is still in the works.
I went with a set of these with the kedge compound https://www.treadwright.com/collections/filter/products/claw-c2616e?variant=5386738691 . With a coupon it was $570 to my door. They should work perfect for what I do with the truck.I ran that size on my ranger. Goodyear duras are $880 at discount. Don't run them at 60psi like the idiot employee did. I ran them at 35-37 and didn't have any issues aside from cracking between treads.
Nah, this one will be fine, it's a bar and plate style. That's a tube and fin core you posted a pic of all ballooned.I remember a thread on the sloppy mechanics Facebook page where someone had blown out one of those cheap intercoolers
I don't know if it would help, but you could probably weld some strips of aluminum from the top to the bottom of the intercooler on the finned section to try and prevent that. 60psi is quite a lot of boost lol
Example pic of what I'm talking about
Ah, ok. Makes sense.Nah, this one will be fine, it's a bar and plate style. That's a tube and fin core you posted a pic of all ballooned.
Nope LOL. I had the flu for 2 days and ended up needing some short radius 2" schedule 40 elbows that weren't in stock anywhere go make the hp to lp hot pipe. They should be here tomorrow and I then can get the LP turbo mounted when Im not out in the woods chasin some does.Is it running yet?
Time is up!
