1 - 5 of 5 Posts
what are the sings that your Transmission control mudule is going bad.... i scaned it and it gave me a P0700 code i think i need to take it to a dealer and have them use a DRB tool on it.. any ideas?... I was running great yesterday and today when i started it up the tec and spedo didn't work.. that's when i scaned it and it gave me that code..
Discussion Starter · #2 ·
ok i think the trans is taking a crap I got these codes now too.... P0740.. TCC CKT Malfunction and P0743 Torque Converter CKT Electrical.... I've replaced the TCM and the input and output speed sensors.... changed the fluid no metal in the pan... maybe the valve body or the torque...? it doesn't start in gear so i'm sure it's not the netural switch... any ideas...
Chillin with the top off.
Check and make sure your trans fuses are good.
Discussion Starter · #4 ·
umm would they be labeled trans fuses.... sorry if that sounds stupid... i'm sure i've checked all the fuses i know of... i'm almost wondeing if theres even any power getting to the TCM .. i haven't checked that yet...
1 - 5 of 5 Posts
