1 - 3 of 3 Posts
Breakaway ®
The first step into serious high performance, the Breakaway® is a great torque converter for moderately modified street machines and weekend racers also used as daily drivers. It provides approximately 2400 to 2600 rpm flash stall with out negatively affecting part throttle driving. Designed for efficiency at highway cruising speeds and to launch hard at wide open throttle, the Breakaway® is a fantastic all-around torque converter.
Features:
Furnace-brazed fins
Needle bearings
Hardened, pre-ground pump hub
Computer Balanced
Installation hardware included
Benefits:
Harder launches
Quicker acceleration
Improved low-end power
Bolt-in (no modifications required)
1000+ rpm increase in stall over stock
For:
1984-97 GM 700R4,
30-spline, 1.703" pilot (will not fit LS1/LS2)
Functional lock-up torque converter only for lock-up transmissions.
12" diameter converter.
TC Is new still in box never used
asking $400
1 - 3 of 3 Posts
