121 - 130 of 130 Posts
Discussion starter · #124 ·
The idea for the phase 2 axle setup:
Rebuild the high pinion dana 30 i have in the jeep in the driveway with a selectable locker and 4.56 gears, and use WJ outers to get rid of the Y style steering. using the WJ hubs and everything puts me on 5x5 bolt pattern, so I am open up to the aftermarket of the JK/JL wheels. Having 5x5 pattern also unlocks me to ordering a matching full float 9" for the rear, probably with a torsen style limited slip. I'd probably bump up to 17" rims, being the more common these days, and may try to squeeze a 34/35" tire without lifting much more if any.
my only wish on the current is that the oem painted rims had 3/8-1/2" less backspacing. Tires to like to rub at full lock. Real glad they are 10.5 width instead of 12.5 with these tires. I'm not sure I can just toss a set of pass through spacers and be comfortable with the leftover thread engagement on the studs
Discussion starter · #130 ·
I dig this! Simple and effective!! Looks nice to boot.
Whats your opinion on the shift kit you put in? How much difference does it make?
my 1-2 shift is maybe a bit too aggressive after doing the drill out for the “hot rod” 1-2. Otherwise no regrets. I do get some chirping in that shift depending on road and driving variables
