I have a 88 Chevy one ton regular cab longbed two wheel drive. It has a 350throttle body injected engine. Has AC (doesn't work but may just need a charge). Body is in somewhat rough shape, but runs and drives great for the miles it has. It has about 229,000 miles. Don't know if its the original motor, but under the hood is really clean and do not see any obvious leaks, and it runs/drives/shifts good. Has a newer battery and alternator. Its got a 14 bolt rear end, unsure of the gears. It would make a good work truck, hauler, or whatever. Located in Paw Paw 1000$
