I will be swapping out my D35 with 30 spline shafts from Superior Axle and Gear. It has an OX locker in it (part-time), and was installed by JCR. It also has new drum brakes as of last winter. 3.73 gears
Little rust and the passenger spring perch is bent on the back (the spring doesn't even touch there, a lot of people cut it off for shock clearance.)
And with the OX.
The cover is much stronger then stock also, not sure on thickness but its heavy. Cable is around 70"
It will have the ebrake cables also.
New was around $1,400 plus install.
$600 obo
And with the OX.
$600 obo
