1 - 20 of 35 Posts
589 Fabrication
Came out of a 78-79 f150, 44 has the cast wedges and is complete with coil buckets and radius arms, has newer mile marker hubs (scratched up but work perfect). Open and i believe it has 3.55s. 9" is a 28spline with a mini spool, right now has no brakes on it but i have disk brake mounts from speedway motors that need to be welded on. Both axles are set up for an XJ but could be put back into the stock truck if needed. Front axle needs ball joints and the knuckles are drilled out for 3/4" hiems but i have other knuckles to go with it and rear may need a pinion bearing. Asking $250 for everything. Everything located in Swartz Creek. Will trade for Band saw capable of cutting 1/4" flat steel.
Tires Sold!
atv rider
is that front axel the same width as a 8.8 out of a ranger? and if so how much
1 - 20 of 35 Posts
