1 - 7 of 7 Posts
Brand New never run 4340 short side axle shaft assembly for a 3/4T Ford Dana 44 front axle (78/79).
I purchased these probably a year and a half ago as a spare set, painted them up to the seals, and they just rode around with me on the trail and got moved around the barn a couple times. Never been installed in the axle.
Specs:
USA Standard Gear 4340 Stub shaft 19 spline 9.72"
USA Standard Gear 4340 Short Side Inner, 30 spline 18.62"
Spicer 5-760X Forged Non-Greasable U-Joint (Still a USA-made version)
All installed, caps tacked
$200 OBO Located in Kalamazoo, MI
Call/Text 269-569-1002
Let me figure out if this is the same length as my 1/2 ton axle, if it is I need it
Sent from my SM-G920V using Tapatalk
Discussion Starter · #4 ·
I believe it is .29" shorter than a 1/2T 44. Should have enough spline to engage
1 - 7 of 7 Posts
