1 - 15 of 15 Posts
YOU ARE LOOKING AT A FULL AIR RIDE SET UP WITH UPGRADED CYLINDERS FOR A 95-99 ECLIPSE/TALON OR A 95-2000 AVENGER/SEABRING. THIS SYSTEM IS USED BUT STILL WORKS GREAT. YOU ARE GETTING IN THIS KIT 4-AIR CYLINDERS WITH TOP AND BOTTOM MOUNTS FOR THE 4 CARS LISTED 1-8 GALLON AIR TANK 1-SET OF 1/2" LINES TO ALL 4 CORNERS 8 SWITCHES FOR FBSS AND PANCAKE/SEASAW 1-SWITCH BOX WITH 10 SWITCHES RED 1-COMPRESSOR FOR FAST FILLING ON YOUR TANK(NEVER USED), I HAD IT AS A SPARE 1 AIR LINE TO USE YOUR A/C COMPRESSOR TO FILL YOUR TANK(CUSTOM SET UP)FAST!!!!(60SEC FROM EMPTY) ALMOST EVERYTHING IS STILL HOOKED UP THE WAY IT SHOULD BE, SO ALL YOU HAVE TO DO IS INSTALL, PLUG AND PLAY! MOST ALL NEW KITS ARE GOING FOR $2200-3000$ ON EBAY SO HIT THIS UP!!! ASKING$ 950.00 obo
1 - 15 of 15 Posts
