1 - 14 of 14 Posts
· MMM Shrimp Slushy
All the parts to make a whole CJ7. Make offers on anything huge discounts on multiple items. $700 for everything CJ that I can find.
Complete Dana 30 Front axle has one new hub and new ujoints. $150
Complete Model 20 Rear axle $150
Frame It has been all cleaned up and patched where it was rusty. The rear section and bumper was replaced with 3" square tubing and the body mounts were repaired as well. It was painted with rusoleum primer and black paint. It also had nerf bars welded on it. $250
Brand new set of stock CJ edelbrock shocks only installed never driven on. $100
Brand New Daystar 1" body lift $100
Tub, It has been repaired in most of the places that there was rust but it still needs more finish work to really be usable. The bed floor and lower sections of the rear wheel wells are new and the floors were patched with heavy gauge steel. The area below the tailgate where the hinges bolt on was also replaced with a piece of tubing. $200
Hard doors are usable but the area that goes around the window is a little flimsy from rust. $100
Fenders are pretty decent except some rust holes in the inner fenders. $100 for both
Good running 4 cylinder 2.5 "Iron Duke" engine $125
T-176 trans $300
Dana 300 $250
15x8 Steel Chrome wagon wheels with pretty worn out 33x12.50R15 BFG AT KOs 5x5.5 bolt pattern $150
Hood good shape just some surface rust $100
2 Tailgates, one is primed the other is white, both are solid and the hinge bolts aren't broken off $75 each.
Grill, seats, roll bar, dash, gauges, steering column, steering box, radiator. All available but I'm not sure on the condition yet because it was decided today that it's getting parted out. I'm planning on taking pictures tomorrow and I'll determine prices then. Everything is OBO and let me know if my prices are way off I'm mostly just guessing. Make an offer on all of it if you'd like to. Some parts are in Clarkston, Some in Holly and I can bring any of them to Flint so let me know what works best for you.
· MMM Shrimp Slushy
Discussion Starter · #6 · (Edited)
I'm not sure on the gears but I know the front has a tag so i'll check on Thursday.
I'm not sure what trans type but the bell housing bolts on and it currently has a Dana 300 bolted to it. It was just apart and re sealed and everything looks ok. It can also come with a brand new clutch that was only ever bolted on.
I forgot my phone at home today so when I stopped to get pictures I couldn't take pictures. The outer fenders are in good shape but the inner fenders have holes in them. I didn't see the grill today when I looked so I'll have to check on that tomorrow when I go take pictures.
· Jackstand Wheeler
Are you sure that trans is a 5-speed? Looks like a T-176 4-speed...which is better than the factory 5-speed anyway....and the bellhousing will also fit a Chevy V8, which makes it desireable, along with the hydro clutch master, slave, and fork. I would say the trans, bellhousing, & hydro clutch parts should net you more than the rest of the Jeep if you find the right buyer.
Good luck with your sales.
· The Dodge Guy
88 ramcharger on tons and 38s
amy better pics of the bfgs? also any pics of the windshield frame? maybe intested in both of them and the body lift
· Who Needs Luck?
very interested in frame, complete body, seats, whatever else is just laying around...
Basically interested in everything but drivetrain. You were asking $700 for everything, PM me with a price for everything but drivetrain.
Thanks
1 - 14 of 14 Posts
