1 - 3 of 3 Posts
Premium Member
Discussion Starter #1 (Edited)
SOLD
NO TRADES
I have a 2002 Chevy 2500hd crew cab long bed has a 6 inch lift and 325/65/18 tires on dropstar wheels with 245k. Truck does have rust on the rockers and one bed side. Has a built trans that was put in April of 2018 has about 20k miles on it and also put a pump rub kit in transfer case at that time. Kit is a stage 5 from alligator performance with a suncoast converter with new bearings and optional c5 clutches and drp hydraulic hose trans lines with a upgraded cooler
Has efi live 5 position switch with built trans tunes from punisher performance
4 inch dual exhaust Kryptonite upper control arms and lower ball joints Ppe heavy duty tie rod ends Volant cold air intake with a 3 inch intake horn Ppe boost valve for the wastegate 3 inch hot side inter cooler pipe
Brake lines were all replaced with new Gm black coated brake lines
Truck is a lt with power heated seats
Front seats had cloth covers installed but still have heating elements and do work as they should. 7800 obo no trades
1 - 3 of 3 Posts
